Res filling help ........
Solved by W-L,
thats a really really long bend
Looks like an EK res, ideally a top like this with an inner tube should be used if your having the fluid flow back through the top, also for filling the reservoir if you have a large syringe it makes things a lot easier.
Ryanwake ·
Posted in General Discussion1 -
1
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases0 -
2
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
10
derekchan ·
Posted in New Builds and Planning16
play_circle_filled
Latest From ShortCircuit:
