nfc allows close range data transfer ( like bluetooth )
it can allow for nfc payments or use of nfc tags to execute apps or commands
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
 but it also acts like a normal mobo right?
It's a normal mobo with a nfc dongle
it's like having a intergrated wifi or bluetooth
