5 fans, 4 headers...
Solved by Master Disaster,
Just to clarify, the H100i has 4 PWM fan headers on the block, the fans for the unit plug into the block and not your MoBo. You then have a single 3 pin connector which connects from the block to your CPU fan header so your board knows you've got a CPU fan connected. I believe you also have a USB header connection to allow Corsair Link to read and control the fans.
