I need to get one or a few APs for my house, I have a budget of $250 and I ALREADY have a pfSense router. I want then to be AC. I was looking at just getting something like a WRT1900AC but I don't know if I should get 3  or so. I live in a 1 story house.
00110000 00110001 00110000 00110000 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110001 00110001 00100000 00110000 00110001 00110001 00110001 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110001 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110000 00110001
https://linustechtips.com/topic/435466-aps-for-250/
if you live in a 1 story house you do not need 3 AC access points. I live in a 3 story, 3,000 sq home. our AC router is in the far corner of the house, the office. the only place it doesnt reach is the basment corner opposite of it. even with a long ranch home, you could get away with just another AP.
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5836353
With our Netgear WNDR4500 (it died D:), my dad wasnt getting good coverage in his room and with our current WNR2000v2 the coverage SUCKS! Would you reccoment this or this?
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5836402
Why not get some extenders ? Or use some old routers as an access point that way you can extend things
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5836936
no! Never get extenders ;)
From those two, the asus one (even tho it looks like a hedgehog)
I would really recommend that you pull some ethernet and place some good access points near where you need the most throughput :)
Ubiquiti are good and cheap.
I believe you can set the asus one up as an AP and connect it to your pfSense box with no problem :)
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5841639
Yes get router extenders :| Use another router if needed mate its better then a powerline connector
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5841719
No :D
Extenders / Repaters act like clients, which will cut your throughput in half for the clients connected to the repeater + they often have limited features in terms of tx power, channel management and heat dissipation (which will impact performance further under load)
Adding an additional router will almost always give some kind of issues (with games and Playstation / Xbox), as you add another NAT and firewall to your network, which can be problematic :)
The way to go is an Access Point of some sort or convert the router to an Access Point from its interface.
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5841730
No :D
yea lol that's what I meant. Of course having two routers being DHPC servers will confuse the shit outta systems
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5841801
How do I setup multiple without having to connect to a different network when I'm on another side of the house?
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5843481
The cheap, quick and easy way would be to use Ubuquiti and set it all up via a centralized controller (UniFi Controller, which is free software) - you only need the controller for setting the APs up and updating them.
If you want the controller accessible all the time (for monitoring and reports), you can either set it up on a linux server or on an AWS server in the cloud.
There is also xclaim which xi-3 Linus has recommended (i have a few of those aswell and they perform very good). Those come with a cloud manager now (which costs nothing) - and you can also just configure them from your phone (that is a cool option).
In both cases, you can have all the APs broadcast the same SSID and WPA2 keys so the clients can roam freely between them :)
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5843608
The problem is that those options are both at the top of the budget for just one.
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5843628
Do you need AC wireless?
You could always get 2 xi-1 or 2 xi-2? :)
http://www.xclaimwireless.com/#products
You could also buy an xi-3 and then add another one later on? :)
I would recommend that you get an AP set up near where you need the most throughput of data and it might reach the rest of the house then.
In my home I have an xi-3 in the living room and a xi-1 near the bedroom, that works very well.
The "pain" is to install the ethernet cabling - when that is first there, its pretty easy to just install another accesspoint if you need to change it later on
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5843689
We just got an upgrade to 100/10 and now none of our wireless devices can get that speed with N so I really want AC now
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5888855
Main Rig:
i7 4790k @ 4.4GHz w/ H75 Liquid CPU Cooler - Asus Maximus VII Hero - 16GB G.Skill Triedent X 2133MHz RAM - 2x Gtx 660s in SLI - 120GB Crucial SSD - 1TB WD HDD NZXT Hue - K70 RGB Keyboard - Corsair Sabre RGB - Windows 8.1 - 2x Asus VN247H-P 1080p Monitors (I'm a sucker for lighting effects)
Server:
FX 8350 @ 4.0GHz w/ stock cooler - 8GB Crucial 1600MHz RAM - AMD Radeon HD 7450 GPU - 300W PSU - 120GB SSD - Windows 7
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5897852
What about the D-link access point listed below. Please note I have no experience with them just adding something else to the discussion.
http://www.amazon.com/D-Link-Wireless-Gigabit-Extender-DAP-1650/dp/B00JFOP688/ref=sr_1_1?ie=UTF8&qid=1440895339&sr=8-1&keywords=d-link+access+point
https://linustechtips.com/topic/435466-aps-for-250/#findComment-5901898
