Hi guys, I'm planning to build my new pc and would like to ask if AMD 8-Core FX 9590 4.7 GHz Processor is compatible with MSI 990FXA GAMING Desktop Motherboard. I would also like to ask if you would recommend MSI Radeon R9 390 Gaming 8G Graphics Card or what would you recommend instead. All this is going to require a lot of power, of how much should my power supply be? Considering the processor requires 220W and for the graphics card they recommend 400W should I go for a 750W power supply or something a bit more powerful in case I add something else to the pc later? And what brand would you recommend for the power supply?
Thanks very much
https://linustechtips.com/topic/435255-help-building-my-pc/
Thanks very much
One, Give us your budget, two the 9590 is trash for the GPU your getting.
https://linustechtips.com/topic/435255-help-building-my-pc/#findComment-5833707
Thanks very much
do you have a link to a website like PCPARTPICKER to make it easier to read (EG:http://uk.pcpartpicker.com/p/K4w8Bm)
https://linustechtips.com/topic/435255-help-building-my-pc/#findComment-5833712
Thanks very much
What is the purpose of this build? Purely gaming?
Budget? Location?
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/435255-help-building-my-pc/#findComment-5833726
you can use pcpartpicker.com , put all yoru parts in there and it will show you if they are compatible or not but from what newegg says it will not since it wont support a cpu needing over 200w
with that said i would also suggest not getting that cpu for gaming, youre better off with an i5 which will be at a comporable price point and be much better
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/435255-help-building-my-pc/#findComment-5833727
im loving my 6600k but you can also get a 4690k for a bit less if you dont want the features the z170 chipset brings
an i7 will always be better but your gonna be raising the price about 100 bucks (or more)
https://linustechtips.com/topic/435255-help-building-my-pc/#findComment-5833744
Thanks for your recommendations. So what i5 would you recommend? Should I go for an i5 or an i7? I want the pc for gaming and also working on 3D modeling and some video editing
I would go for any i7 with a k at the end of the model in a LGA 1150 or LGA 1151 socket.
But the FX should be fine for 3D modeling, since multi core workloads is the only thing it is good for.
(It doesn't preform that well in gaming though)
https://linustechtips.com/topic/435255-help-building-my-pc/#findComment-5833752
both are good cards, the 290 x will outperform slightly but the 390 has more vram which may come in to play a bit later on when games start needing more and more ram
https://linustechtips.com/topic/435255-help-building-my-pc/#findComment-5833819
