Hello,
I recently purchased four noctua PWM fans to replace the stocks ones that came with my case. Looking for heredity a 5.25" driver bay controller with a basic front control so that it won't stand out in my office or an internal hardware controller.
PS I know i probably could run them threw my motherboard but would like to avoid it unless it is a clear cut winner.
Thanks,
Adam B
https://linustechtips.com/topic/435216-fan-controller-options/
Any reason why you would want a fan controller instead of running the fans off of the motherboard?
https://linustechtips.com/topic/435216-fan-controller-options/#findComment-5838795
