Hi guys, I'm planning to build my new pc and would like to ask if AMD 8-Core FX 9590 4.7 GHz Processor is compatible with MSI 990FXA GAMING Desktop Motherboard. I would also like to ask if you would recommend MSI Radeon R9 390 Gaming 8G Graphics Card or what would you recommend instead. All this is going to require a lot of power, of how much should my power supply be? Considering the processor requires 220W and for the graphics card they recommend 400W should I go for a 750W power supply? And what brand would you recommend for the power supply?
Thanks very much
https://linustechtips.com/topic/435058-help-building-my-new-pc/
Thanks very much
I'd recommend to go with an Inter CPU instead , for the PSU either get EVGA, Seasonic, or SuperFlower
https://linustechtips.com/topic/435058-help-building-my-new-pc/#findComment-5831265
Thanks very much
we need a budget
currency type
country
and when you are building it
and if you bought any parts yet?
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/435058-help-building-my-new-pc/#findComment-5831377
