I am looking for software that I can run that will allow me to set my fan speeds based on temperature. The software needs to be able to control the RPM of the 2 fans on my H80i and the fan on my AMD GPU.
Cannot use Corsair LINK as it will not allow me to adjust RPM based on the CPU temperature not the water temperature.
I5 4670k | 7870 Tahiti LE | 1600MHz 2x4GB
https://linustechtips.com/topic/43489-fan-speed-software/
Corsair link for the h80i.
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
https://linustechtips.com/topic/43489-fan-speed-software/#findComment-568208
I have it but I want to set profiles so when my CPU is below 40c my fans run at 25%, between 40c - 50c running at 50% and 60c + at 75% and at 90c+ 100%
I also want my GPU to run at 50% but when over 70c run at 75%
https://linustechtips.com/topic/43489-fan-speed-software/#findComment-568220
Msi Afterburner for the GPU.
https://linustechtips.com/topic/43489-fan-speed-software/#findComment-568374
