I need help
Nicholas15
I want to upgrade my gpu, this is the first time I have bought a gpu on its own, I went into system and looked at device manager, then display adapters too find out what card I have atm but it tells me I have 2, I clearly only have one however, It says I have an AMD Radeon R7 200 series and a Intel® HD Graphics 4600, can anyone help me?
intel hd is what is on your cpu. you can turn it off in BIOS however for your exact gpu download gpu z and it will tell you everything
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
u still got ur onboard graphics enabled in the bios, disable onboard graphics and ul only see the amd (◑‿◐)
The Intel HD Graphics is the one that comes with your CPU. It is a GPU, but on your CPU. You know those DVI,VGA, and HDMI ports on your motherboard you never use? Yea, that's what they're for. Don't use them. The R7 200 Series is your actual dedicated GPU, and the one you should be plugging stuff into.
If you're still on an R7 2xx GPU, a good upgrade might be an R9 380.
I was going to just buy another and run crossfire, Im getting a whole new system in december and this will go to my brother
How can I tell what GPU I actually have?
Download GPU-Z
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
The GPU that you're using is the one your monitor is plugged into. If it's plugged into the motherboard, you're using the Intel HD graphics. If it's plugged into your GPU, you're using the AMD R7 2XX graphics.
