I need help making a parts list for the following:
  • Peripherals: none
  • Use: Only Minecraft - no other games will be played on this build
  • Use: Youtube - able to record 1080p videos (of Minecraft gameplay) & able to edit videos without any problems
  • Budget: $500
Thanks!
https://linustechtips.com/topic/434489-help-500-minecraft-youtuber-pc/
Look at my specs. I can record full 1080p60.
Mind you, I also got most of my items on sale...
GIGABYTE Z97MX-G516GB DDR3 | I5 4690k @ 4.4ghz | 1TB SSHD, 500GB HDD, 128GB SSD | GTX 1070 8GB | Corsair Graphite 230 | EVGA 650W | Hyper 212 EVO
Cinebench R15: 636(all cores), 127FPS
  • Peripherals: none
  • Budget: $500
Thanks!
here should be fine for minecraft at 1080p while recording
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($71.89 @ OutletPC)
Memory: Mushkin Silverline 8GB (2 x 4GB) DDR3-1600 Memory  ($42.89 @ OutletPC)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card  ($174.99 @ NCIX US)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($32.99 @ Micro Center)
Power Supply: Antec Green 450W 80+ Bronze Certified ATX Power Supply  ($29.99 @ Newegg)
Total: $507.74
Generated by PCPartPicker 2015-08-20 22:56 EDT-0400
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($96.89 @ OutletPC)
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard  ($79.99 @ Amazon)
Video Card: MSI GeForce GTX 750 Ti 2GB Video Card  ($123.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($59.99 @ Micro Center)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($51.99 @ SuperBiiz)
Total: $506.71
Generated by PCPartPicker 2015-08-20 22:58 EDT-0400
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
This will do you really well
EDIT: Looks like I managed to get the cheapest price +  the best specs so far.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.99 @ NCIX US)
Motherboard: Biostar Hi-Fi B85S3+ Ver. 6.x Micro ATX LGA1150 Motherboard  ($58.00 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($43.99 @ Newegg)
Storage: Toshiba Product Series:DT01ACA 1TB 3.5" 7200RPM Internal Hard Drive  ($46.99 @ NCIX US)
Video Card: Sapphire Radeon R9 270X 2GB Dual-X Video Card  ($129.99 @ Newegg)
Case: Raidmax ATX-402WB ATX Mid Tower Case  ($24.99 @ Newegg)
Power Supply: EVGA 400W ATX Power Supply  ($27.99 @ SuperBiiz)
Total: $506.94
Generated by PCPartPicker 2015-08-20 23:01 EDT-0400
Total: $506.94
I would go with this one especially because you are a youtuber, you would need a strong cpu, the gpu doesn't matter as much
Total: $506.94
do not get that psu http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/
except for the psu > the motherboard most people iirc say they dont make good motherboards
http://pcpartpicker.com/p/N46J99
use ubuntu because it has recordmydesktop, one video recording app that makes very good quality videos
Intel Core i5-4460 3.2GHz Turbo 3.5GHz | 8GB Kingston DDR3-1333 | MSI Radeon R7 370 OC to 1020mhz | EVGA Supernova NEX B1 750W | GIGABYTE GA-B85-D3H | Inwin Velocity OEM Case | 120mm broken fan
Vancouver, BC | O Canada
except for the psu the motherboard most people iirc say they dont make good motherboards
Here, I switched out the components you guys pointed out, made it a little cheaper as well. Only downgrade is less RAM slots.
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($42.89 @ OutletPC)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($27.99 @ NCIX US)
Total: $491.83
Generated by PCPartPicker 2015-08-20 23:15 EDT-0400
Total: $491.83
you could also change the hdd to the hitachi one i put in my build cause i've heard a lot of bad things about toshiba and i know that hitachi makes pretty reliable hdds and its cheaper oherwise i'm done picking out problems i see except iirc minecraft doesn't like amd cards but i could be wrong about that
Total: $507.74
I think I'm going to go with this build..
well @Chasem121 build is good too
Total: $491.83
Going with this then!
GETTING THIS RN:
Total: $494.72
Generated by PCPartPicker 2015-08-20 23:27 EDT-0400
Dear god do not go with a dual core cpu for video editing, it would be better to get a FX cpu than that.
well it does have hyperthreading so it will be fine 2 threads for minecraft and 2 threads for the recording software also nvidia does have shadow play which doesn't use the cpu iirc
hold on sestrie I have a better build for you, give me one second
Archangel(z11 Build) CPU: Ryzen 7 1700 @ 4.0 GPU: 2x Sapphire R9 290x RAM: 16GB GSkill Ripjaws V 2800 Mobo: ASRock X370 Killer SLI/AC Power Supply: Cougar CMX1000 Case: Zalman Z11 Plus HF1 Storage: 120GB Intel 520 SSD, 1TB WD Blue
Reptile(Dual G34) CPU: 2x Opteron 6172 RAM: 32GB DDR3 1866 ECC Mobo: Super Micro H8DGU-F Power Supply: Seasonic SS-660XP2 Case: Phanteks Enthoo Pro Storage: Hitachi Ultrastar 7k300 3TB
White Knight:(wife's build) CPU: A10-6800k GPU: MSI 7970 Lightning GHz BE RAM: 8GB HyperX Fury White 1866 Mobo: MSI A88x-g43 Power Supply: Seasonic M12II 520 Case: TT Commander Snow Edition Storage:1TB WD Blue
If you wanted to skip the SSD and get a HDD for more storage atm you could, but honestly I'd get the SSD first and grab either a HGST or WD hard drive in the future when you get a little extra cash. You wont regret it.
@Chasem121 is better and that ssd is not worth it
Total: $491.83
oh and OP if your willing to spend a bit if your willing to spend a bit more than $500 than this one will be the best with out going too far out of your budget
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($178.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H81M-H Micro ATX LGA1150 Motherboard  ($43.98 @ Newegg)
Total: $538.83
Generated by PCPartPicker 2015-08-20 23:43 EDT-0400
Again
Total: $538.83
You realize he is playing minecraft and editing videos, the SSD is worth it. having a 960 is not worth it for him. And suggesting shitty business motherboards and using all the available memory slots is dumb. He would have to buy an entire new motherboard just to add a second card or for that matter any other full length pci-e card. Please don't suggest sub-par components for people. My build gives him the ability to upgrade to more ram in the future(up to 32GB) as well as having multiple gpus etc. Not only that the SSD will be orders of magnitude faster than any 7200 rpm drive and for editing that will be key.
