Help me choose :/
Go to solution Solved by Comessy,
For the PSU, an EVGA B2 should work. G2 if you have the money.
For the case the H440 and S340 are both solid, with the H440 being the superior option. I don't have enough experience with the storm trooper to know.
So I am building a new build and I am having trouble choosing a PSU and a CASE.
My Build:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($145.89 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card  ($329.98 @ SuperBiiz)
Total: $891.70
Generated by PCPartPicker 2015-08-20 12:27 EDT-0400
The problem with choosing a PSU is that I don't want to go wrong here. The PSU is like the heart of the PC and I don't want to regret later because I made a bad choice.
What I want to know :
1)Which one would you put in your pc if you were building this exact build?
2)Why you choose that PSU into this build?
3)Don't really cheap out but don't overkill either. I want a good Price/performance PSU
 The Case I went looking for it and really liked a lot of them. The ones that got my attention were the Storm Trooper , The NZXT h440 and the s340 that are in different price ranges. My doubts here are
1) Which one of this is the best price for what they are deliviring
2) Is the difference in this 3 cases high? Or would I be happy with either of them?
3) What would you get if it was you?
I would like some good opinions from you people
Thanks :D
https://linustechtips.com/topic/434121-help-me-choose/
Intel Core i7 9700k - EVGA FTW GTX 970
https://linustechtips.com/topic/434121-help-me-choose/#findComment-5818254
My Build:
Total: $891.70
Thanks :D
EVGA for the psu....see your other thread.
If you want a cheaper case then the S340 is good. Otherwise I would go with the H440 out of those three.
https://linustechtips.com/topic/434121-help-me-choose/#findComment-5818259
EVGA G2, GS, or B2. Any XFX or SeaSonic PSU.
For the case choose what your heart desires.
( P.S.Get a BeQuiet! Pure ?Rock for the CPU Cooler )
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/434121-help-me-choose/#findComment-5818301
