Is it Possible to Format Drive C?
Solved by MeesterJackson,
You should be able to reuse the same key on the same computer (different drive). You don't need to remove the old OS, simply disconnect the drive from the computer while you are installing the new OS on the other drive and then reconnect it and delete the old OS's partitions. You would need to reinstall all the applications and games due to the registry.Captain_WD.
Actually, I just went into the command prompt and uninstalled the product key. A friend of mines who's good with PC's was online so I asked him.
