Hello, I'm planning on building my first pc and I'd like your advise if the parts I have in mind are a good set up.
MSI Computer Corp. ATX DDR3 2400 Motherboards A88X-G45 GAMING AMD FD8350FRHKBOX FX-8350 FX-Series 8-Core Black Edition
Sapphire Radeon NITRO R9 390 8GB GDDR5 DVI-D / HDMI / TRIPLE DP
Corsair CX Series 850 Watt ATX/EPS Modular 80 PLUS Bronze ATX12V
Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan
NZXT Source 530 Full Tower Chassis, Black Mesh CA-SO530-M1
https://linustechtips.com/topic/433066-first-pc/
You NEED to change that PSU. It is for very basic builds and has been known to start fires and destroy your PC.
Get a Seasonic or XFX
https://linustechtips.com/topic/433066-first-pc/#findComment-5804652
Go intel or go home..../my two cents.
MainRig- CPU: 4790k, RAM: 32gb 2400mhz, MOBO: Maximus Formula VII, COOLING: Full EK cooling, GPU: Titan X SLI, PSU: 1200w evga , STORAGE: 250gb SSD, 4TB hybrid CASE: 760T, EXTRAS: Sleeved cables
SecondRig- CPU:4690K, RAM: 16gb 1600mhz, MOBO: Maximus Gene VII, COOLING: H105, GPU: 970ftw, PSU: EVG650W,  STORAGE: 250gb SSD, 3TB, CASE: 540air
Steam: pizzatime6 Plus two other pc rigs and a craptop.
https://linustechtips.com/topic/433066-first-pc/#findComment-5804672
Will either seasonic or xfx 850 Watt would be ok
Not sure if this is within your budget but I just picked one of these up and its been pretty good so far
http://www.amazon.co.uk/XFX-ProSeries-Edition-Modular-Supply/dp/B00B88Z314
CPU: FX-6300 GPU: Sapphire R9 380X MOBO: Gigabyte 970A-DS3P RAM: Corsair Vengeance 8GB PSU: XFX XTR 550W CASE: Zalman Z11 Plus SSD: Samsung 840 Evo
17 years old, PC Enthusiast for 3. Be gentle with me, I'm only young.
https://linustechtips.com/topic/433066-first-pc/#findComment-5804701
Yeah that will be fine, just check the amp rating to ensure that it will support the GPU (it most likely will but always worth double checking).
Have you thought about a 290? might save you a bit of cash if your not planning on going 4K
https://linustechtips.com/topic/433066-first-pc/#findComment-5804710
Also, take it from a guy who has an AM3+ CPU, you will want to upgrade it to an Intel sooner or later so if I were you I'd get an Intel CPU of similar price.
AMD are all good but there is no where to go from there
https://linustechtips.com/topic/433066-first-pc/#findComment-5804730
Yeah that's good I was picking the 390 since it was a good price. 1080 I think is still very good resolution
https://linustechtips.com/topic/433066-first-pc/#findComment-5804762
Go intel.
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/433066-first-pc/#findComment-5804775
What's the best intel cpu under $200??
Probably the i5-4460, as long as you don't want to OC
https://linustechtips.com/topic/433066-first-pc/#findComment-5804844
Yeah I don't plan on over clocking my first pc.i want something I can have for long time and in the long run upgrade some components in the future
Defintely that 4460 then, unless you want to wait for Skylake but from what I know its not worth the price difference
https://linustechtips.com/topic/433066-first-pc/#findComment-5804893
Is intel much better? I been looking around and I believe I get more value out of an amd or am I wrong
Ur wrong get the cheapest H97 motherboard and a i5 4460 and u will game way better
https://linustechtips.com/topic/433066-first-pc/#findComment-5804948
Will the i5 4690k be better if I up my budget for that cpu??
There's not a big difference in performance, only real difference is the ability to oc
https://linustechtips.com/topic/433066-first-pc/#findComment-5804967
Ok. Any other advise you have that I can use?
U should be all set now
https://linustechtips.com/topic/433066-first-pc/#findComment-5805086
