hello pc enthusiast community,
    i recently just rma my cpu and they gave me a new cpu and it seems to be getting too hot. I downloaded hwmonitor and it shows that my cpu is at 60-68 at idle. i am using stock amd heat sink with the cooler master thermal paste that came with hyper 212 evo, because i had to swap out my mother board. what should i do from here? thanks i will pick a best answer.
PC build:
Wind 8.1 64bit
MSI A78M-E35
AMD athlon x4 760k
R7 260x 2GB OC
Crusial Ballistic Sport 1x8 ddr3 1600
West Digital Blue 1tb 7200rpm
corsair cx430
https://linustechtips.com/topic/432307-cpu-thermal-throttling/
heatsink is properly seated and i put a pea size dot in the center.
reapply and try again
The Brokish Boy v1: CPU: i7-8700k GPU: MSI Gaming X GTX ti MOBO: Asus ROG Maximus X Code Ram: G.Skill Trident Z 4x8gb 3200mhz DRIVES: 2x3TB WD Black , 500gb Samsung 850 EVO SSD, 500gb 970 EVO SSD Case: be quiet! Dark Base Pro 900 Black Headphone: ATH-MSR7 Mic: Blue Yeti Monitors: 27" BenQ GW2765 1440p; IPS, 27" Acer Predator XB271HU 1440p; VA
https://linustechtips.com/topic/432307-cpu-thermal-throttling/#findComment-5795385
i tried that same problem
did you try different thermal paste?
https://linustechtips.com/topic/432307-cpu-thermal-throttling/#findComment-5795580
no
Try that, is the fan on the heatsink spinning? How's airflow in your case?
https://linustechtips.com/topic/432307-cpu-thermal-throttling/#findComment-5796000
When you removed the heatsink, was the thermal compound reaching the entire CPU?
For me, those "pea sized dots" just aren't enough to cover the whole surface, and as such, performance takes a huge hit.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/432307-cpu-thermal-throttling/#findComment-5796045
I normally do a 1 1/2 pea sized dot
https://linustechtips.com/topic/432307-cpu-thermal-throttling/#findComment-5797023
