Cpu Name Problem
Go to solution Solved by byalexandr,
Hello!
I'm building a pc for the first time and i don't understand something. So my question is:
Intel I5-4690 BX80646I54690
 what does the long number stand for and should i worry about it when i'm looking for deals
Nope, it's an i5-4690 and that's it. That number is just the SKU.
Hello!
https://linustechtips.com/topic/432104-cpu-name-problem/#findComment-5792823
Hello!
All you need to know is that the cpu is an i5-4690.  Don't worry about that code.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/432104-cpu-name-problem/#findComment-5792824
I think the code only matters when you buy it at the same website where you found it with that code.
|Intel Core i5-4670K| |Gigabyte Z97P-D3| |Seagate 1TB SSHD| |Fractal Design Define S| |Corsair CS650M| |Asus PB278Q| |Cooler Master CM Storm Devastator Bundle|
https://linustechtips.com/topic/432104-cpu-name-problem/#findComment-5792828
Don't worry about that long code. It's just an i5-4690
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
https://linustechtips.com/topic/432104-cpu-name-problem/#findComment-5792843
