Really though? I know ethernet can carry audio in some capacity. And if not, what is this for?
http://www.amazon.com/Headphone-Jack-3-5mm-Audio-Balun/dp/B00D0E206A/ref=sr_1_1?ie=UTF8&qid=1439848687&sr=8-1&keywords=ethernet+to+3.5mm
don't think the sonos is meant to receive audio over Ethernet (well it is, but not anoloug audio)
That appears to be used to use an Ethernet cable as a 3.5mm extension cable
the Ethernet just acts as a basic cable their.
https://linustechtips.com/topic/432055-sonos-play-3-help/#findComment-5794194
Well, you could probably get a USB OTG cable then a USB to ethernet adapter, and use that. I don't know 100% if that would work though...
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
https://linustechtips.com/topic/432055-sonos-play-3-help/#findComment-5794371
I could see that working.
Not sure if it would, but it should.
https://linustechtips.com/topic/432055-sonos-play-3-help/#findComment-5794729
