Power button not responding
Go to solution Solved by SPAS-ID,
make sure u properly connect those wire
Okay so the PSU died in my sister's old pc, since its prebuilt it was a really crappy PSU so i just grabbed another PSU from a prebuilt unused pc and put it in there, power button didnt work but the green light  turned on from the PSU, i then tried a different old PSU same results. So Im beginning to assume that theres some cable im missing to plug between the power button to the actual PSU if thats a thing, which it probably is.
https://linustechtips.com/topic/431586-power-button-not-responding/
