as some you know, i tried to reinstall Windows 10. I used the reinstaller that was on the system. I chose the wipe disk thing. 16% in the computer shut down, and got the error Message: inaccsesible boot. Now when I turn it on it just comes to the blue screen and restarts. This happends everytime. Ant help? I'm writing this fron a phone
My current system is: | CPU: i7 2600 3.40GHz | RAM: 12GB Dual Channel DDR3 1600MHZ | Motherboard: CG8350 | Storage: 931GB Seagate+Samsung 850 EVO Series 250GB | GPU: GTX 970 Gaming | PSU: G2 750 | Monitors: 2x BenQ XL2411Z
https://linustechtips.com/topic/431482-big-problem/
try entering your BIOS and from there select the the USB drive or whatever you used to install windows
[spoiler=My PC]
CPU: Intel Core i7 6700K | COOLER: Corsair H105 | MOBO: ASUS Z170i Gaming Pro AC | RAM: Corsair LPX DDR4 16GB 2400MHz | GPU: EVGA GTX 980 Classified | CASE: BitFenix Prodigy | SSD: Samsung 950 Pro 512GB | PSU: XFX XTR 650W [spoiler= Le Other Stuff] Monitor: BenQ XL2411Z | Keyboard: Ozone Strike Pro | Mouse: A4 Tech X7 F4 | MousePad: Ozone
PlayStation 2 | PSP 2000 | Game Boy Color | Nintendo DS Lite | Nintendo 3DS | Wii
Sony Xperia J (Why u so bad D:) | iPod 4th gen | iPhone 4 | Yarvik Xenta 13c (3muchchrome5her)
Pentium B980 | 500GB WD Blue | Intel HD Graphixxx | 4Gegabeytes of REHAM
Current OS: MSX 10.0 ( ͡° ͜ʖ ͡°)Ilikethelennyfaceyouknow( ͡° ͜ʖ ͡°) Windows Password Reset Guide
https://linustechtips.com/topic/431482-big-problem/#findComment-5785060
Nope, never deleted it
download win10 from another computer and put it on a USB stick and do what I said
[spoiler=My PC]
https://linustechtips.com/topic/431482-big-problem/#findComment-5785103
Problem is that I only have 1 computer currently
https://linustechtips.com/topic/431482-big-problem/#findComment-5785109
go to a friends computer, or.....
[spoiler=My PC]
https://linustechtips.com/topic/431482-big-problem/#findComment-5785157
Its 23.30 and work/school tommorrow. Everybody is asleep
https://linustechtips.com/topic/431482-big-problem/#findComment-5785176
So there is no way to fix it without another computer?
https://linustechtips.com/topic/431482-big-problem/#findComment-5785253
don't have any usb device with windows on it?
That is a must
Do this ASAP
and keep it forever (till next version of windows then update it)
http://www.microsoft.com/en-us/software-download/windows10
https://linustechtips.com/topic/431482-big-problem/#findComment-5785257
I can't do that now tho, i can't Even Get into my pc, only the bios
https://linustechtips.com/topic/431482-big-problem/#findComment-5785268
Now i have the iso on my USB, had to call up a friend
https://linustechtips.com/topic/431482-big-problem/#findComment-5785410
ok nice now go into the BIOS and boot from the USB stick
[spoiler=My PC]
https://linustechtips.com/topic/431482-big-problem/#findComment-5785494
One problem, i had to install the iso to a DVD plate, Does that Even work?
https://linustechtips.com/topic/431482-big-problem/#findComment-5785587
