Yes, because air is needed to remove heat from the radiators attached to the water cooling loop. With an external system (whole room water cooling) the radiators are outside but there still needed to be some airflow to cool the motherboard and ram etc.
"If in doubt, use a bigger hammer" Anonymous
https://linustechtips.com/topic/431404-question-about-airflow/#findComment-5784152
You've basically just answered your own question. Plus since the radiators are going to be mounted inside the case, and the radiators need fans to get the heat out of the coolant, you still need fans to move air for any remaining heatsinks (plus some components on the mainboard will still radiate heat and that needs to be cleared away) and for the radiators. It's always best to have some intake and exhaust fans that aren't going through radiators. I have one intake and one exhaust in my build that don't go through radiators.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/431404-question-about-airflow/#findComment-5784162
I mean yes and no. If have 360+ mm of radiator exhaust you really don't need any other fans as the air they pull through comes fresh into the case and cools everything else.
It's always a good idea though to have separate fans as they push well over 2x the air of standard radiator fans. If using 240mm of radiators or less you DEFINITELY want additional fans, but you can just use whatever came with the case.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/431404-question-about-airflow/#findComment-5784190
If I theoretically had all my components liquid cooled (AIo on CPU, G10 and AIO on GPU), would I need any intake/exhaust fans? Concerns are the Mobo Heatsinks and RAM Heatsinks that may need a bit of air flowing over them.
The rads can be exhaust and intake, but the airflow gets restricted through a rad, and for good aiflow, particularly for the mobo chipset, better to have some extra fans, specially if you are using let's say a 240mm and a 120mm or similar, since that wouldn't provide enough airflow. If you have the dual on top and the single on the rear, adding a couple of fans on the front should be enough.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/431404-question-about-airflow/#findComment-5784568
