Hey,
I'm looking at the spec03 and the hyper 212 evo, but the evo is 2mm too tall for the spec03,
I'm looking for recommendations of CPU coolers that would fit and work good?
Thanks in advance.
Cooler Master T2, TX3, T4. They're all smaller than the 212 and cool very well. Just depends what fits in your budget. However if you can save the extra 30$ over the 212 I'd recommend getting a Corsair h60.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/431400-spec03-cpu-cooler/#findComment-5784093
Hey,
Thanks in advance.
I would like to suggest the noctua NH-L9i, its fairly silent and the cooling is top
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/431400-spec03-cpu-cooler/#findComment-5784387
Cryorig H7
Smaller dimensions and a lot of sources claim it cools better than the 212 evo.
And it's quiet + looks good + same price
http://www.techpowerup.com/reviews/CRYORIG/H7_Universal/6.html
It does look cool! But on Amazon UK it would cost £20 to ship to me in the UK
https://linustechtips.com/topic/431400-spec03-cpu-cooler/#findComment-5784505
