What is the best all in 1 cpu watercooler? I have a i5-4690k and Im going to overclock but what would be the best cooler? preferably 120mm mounted fans?
well depending on your case support:
best: http://pcpartpicker.com/part/nzxt-cpu-cooler-rlkrx6101
better: http://pcpartpicker.com/part/corsair-cpu-cooler-cw9060021ww
ok: http://pcpartpicker.com/part/corsair-cpu-cooler-cw9060017ww
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/431340-cpu-cooler/#findComment-5783378
For 120mm fans, i'd say Corsair H105, Enermax Liqtech 240, Cooler master Nepton 240M (If you prefer not to buy fans, since all the other coolers come with so-so fans)
The Corsair H105 is thicker, so it gets more performance than typical 240mm rads
The Enermax liqtech is built very well, the thing is a tank, and it is almost as good in temps as the H105
The Nepton 240M comes with good performing and relatively quiet fans, something that can mean a lot for people who dislike fan noise, specially compared to corsair, which for me requires changing the fans since stock corsair fans are stupid loud
I went with the H105, best overall raw performance at a good price
https://pcpartpicker.com/part/corsair-cpu-cooler-cw9060016ww
https://pcpartpicker.com/part/cooler-master-cpu-cooler-rln24m24pkr1
https://pcpartpicker.com/part/enermax-cpu-cooler-elclt240hp
All 3 should be able to handle the heat of your CPU and let you overclock at high voltages.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/431340-cpu-cooler/#findComment-5783702
