Another HP Laptop issue....
Solved by colonel_mortis,
No issues with running CHKDSK nothing bad detected, but I still have the same warning errors from HD Tune
Yeah, they just mean that your drive is slowing down because it's been used a lot and is only rated for a certain amount of hours/spins etc, so is beginning to wear out. It will probably get slower to read the data, and might become corrupt in the future, but for now it's simply not running at it's optimum working conditions.
