Hello!
Im wondering if any one knows any PSU's that is 750w with black flat cables thats around $70ish. The  EVGA SuperNOVA NEX 750W apparently has all that but when people use it in their builds it shows it has multi colored cables, which gets me confused. So if someone can confirm it does have all flat black cables that would be great.
https://linustechtips.com/topic/430807-psu-help/
Hello!
EVGAs 550W GS is good. What do you need 750W for?
https://linustechtips.com/topic/430807-psu-help/#findComment-5776423
There are two versions of the NEX750B.
A 120mm fan version and a 135mm fan version. The one from the link that you posted is the 135mm version with black cables.
The 120mm one has some weird colored cables.
That cleared up a lot thank you SOOOO much!
https://linustechtips.com/topic/430807-psu-help/#findComment-5776451
I'm probably and most likely going to sli in the future with gtx 970's
650W will be fine if you have two 970s provided you aren't using an FX CPU overclocked to 5 GHz. Check out the G2 or GS from EVGA. NEX series has poor VREG
https://linustechtips.com/topic/430807-psu-help/#findComment-5776471
the  problem is money… I'm on a budget ish
The GS and G2 are like 3 dollars more if you look... Also check out the Antec High Current Gamer 620W +
https://linustechtips.com/topic/430807-psu-help/#findComment-5776641
