8350 overclocking help and suggestions
Go to solution Solved by bamerx98,
I think I'm going to get this kit here http://www.aquatuning.us/index.php/cat/c308_S-939-AM2-AM3-Kits.html and then I might add a 360 after as my case will support it with a few little mods
I currently have a 8350 on a Asus m5a99x evo r2.0 and a hyper 212 Cooling the 8350 I currently have a 4.4ghz oc and this keeps the socket under 65 under prime 95 I was wondering what CPU cooler I should get to replace the 212 ? Also suggest some oc settings I dont really know what to do with the vcore on this CPU I'm really used to the phenom but the 8350 seems to react more to vcore changes
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/43075-8350-overclocking-help-and-suggestions/
How about custom loop?
i have 8350 at 5.3Ghz, and temps are under 60c
If my information is correct, you can stick a Kraken x60, H110, or H220 in that case.
If you're unhappy about the 212 Evo you could go with Noctua's U14S or Xigmatek Dark Knight or look into an AIO cooler like the H100i.
Overclocking questions are going to have be answered by someone else not that great with overclocking.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
For overclocking, increase voltage sparingly. What is your voltage currently?
I haven't touched the voltage but when I set it to 1.35 vcore my temps went up to 80c in a heart beat, Im just not satisfided with knowing I could have better performance
What would be your suggestion for parts for a custom loop ? (Water cooling noob)
Yes the case has support for a 280 or 240 in the front and top
Before overclocking further, get a better cooler. Those temps are pretty high for any overvolting.
I don't see a point in upgrading unless you really want then a H220 since you are not in the States
I just want more performance out of the CPU I don't like knowing that I could be getting higher performance. I don't think you can get the h220 in Canada yet either ?
How much is your budged?
Here is cheap:
http://www.aquatuning.fi/product_info.php/info/p13669_Alphacool-NexXxoS-Cool-Answer-240-LT-ST---kit.html
That's what I thought what would you reccomend h220 looks good but I can't find any Canadian retailer with it in stock ?
I don't know what you mean but yes you can get one in Canada but you will have to wait till the 23rd http://ncix.com/products/?sku=79583&vpn=H220&manufacture=Swiftech&promoid=1294
Would you mind shopping on eBay?
Never mind.
Cool
Never mind.
To be honest I don't mind eBay just I live in Canada and don't wanna deal with boarder fees
um, right now your not going to get anymore performance until you upgrade your GPU, maybe get a 680, 7970, or 770, overclocking the cpu right now is pointless as the GPU is bottlenecking the 8350
My System
CPU - 3570K@4.4Ghz | CPU Cooler - Corsair H100 in pull | Motherboard - ASUS P8Z77-V PRO | RAM - G.Skill RipJawX Blue 8GB 2133Mhz | GPU - Gigabyte Windforce X3 HD7970 | SSD - Patriot Pyro SE 120GB | HDD Seagate Barracuda 3TB | PSU - Corsair TX850V2 | Case - Bitfenix Shinobi XL
I'm not going to be upgrading the GPU it does the job for now, its a 7870 xt aka a 7930 its not worth upgrading right now, I'm wanting to over clock the CPU more to get better render times I do a lot of work in video editing software and sound creation and I enjoy my 8350 and dont wanna spend 500 dollars for Intel and get a 5% performance increase. I just wanted to get suggestions on overclocking the 8350 and what cooler I should get
yeah I think I'm just going to get a custom loop kit, it seems to be the best option for me right now.
The CPU will benefit with higher overclocks in CPU intensive games, such as Skyrim, Crysis 2-3, Far Cry 3, and Battlefield 3-4.
i went from a 4.4Ghz 6100 to a 3570K @4.6 and the only difference i notice is in sony vegas, no difference in games at all
My System
