http://pcpartpicker.com/p/32pR3C
Games I will be playing
- ARK survival evolved
- CS:GO
- GTA V
- Witcher 3
If you guys could give me suggestions on other parts or opnions on the parts that would be great!
Im also expecting this PC to last for about 3-4 years on medium settings!
Also if any of you have a method for getting windows 7/8 for free PLEASE msg me! ( i'v checked yt but everything seems outdated )
https://linustechtips.com/topic/430235-future-first-build/
You can get windows 7/8 off of reddit for like $20.
Edited Build (please don't get the CX power supply and get that EVGA one instead other then that all good)
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.95 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($67.98 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($49.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 960 2GB Video Card  ($199.99 @ Amazon)
Case: NZXT S340 (White) ATX Mid Tower Case  ($59.99 @ Micro Center)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($51.99 @ SuperBiiz)
Monitor: Acer S220HQLAbd 60Hz 21.5" Monitor  ($99.99 @ Amazon)
Total: $756.66
Generated by PCPartPicker 2015-08-14 18:39 EDT-0400
Insert   Dank   Signature   Here.
https://linustechtips.com/topic/430235-future-first-build/#findComment-5769729
Motherboard: ASRock H97 PERFORMANCE ATX LGA1150 Motherboard  ($79.99 @ Newegg)
Case: Apex Vortex 3620 ATX Mid Tower Case  ($29.99 @ Directron)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer  ($13.99 @ Newegg)
Total: $767.35
Generated by PCPartPicker 2015-08-14 18:44 EDT-0400
Go pick up a windows key from Reddit, dont expect to be maxing everything
Your funny if you think any PC under 2,500 will last more then 4 years
https://linustechtips.com/topic/430235-future-first-build/#findComment-5769769
Neither is a great psu. But the CX is at least as good as the EVGA.
http://www.techpowerup.com/reviews/Corsair/CX600M/11.html
http://www.techpowerup.com/reviews/EVGA/600B/11.html
OP build looks decent.
https://linustechtips.com/topic/430235-future-first-build/#findComment-5769824
- CS:GO
- GTA V
- Witcher 3
Look at G2A for Windows keys. I have brought 4 keys off there, one didn't work so I used the G2A Shield got my money back with no worries. You can get 8.1 for around $35 and 8 for $23 but finding the windows 8 install download is a bit harder. Also don't buy the cheaper OEM versions are they are for one time use and get locked to the motherboard
https://linustechtips.com/topic/430235-future-first-build/#findComment-5769830
A better PSU then all three. Also has $30 off at the moment from Newegg
http://pcpartpicker.com/part/evga-power-supply-110b20750vr
https://linustechtips.com/topic/430235-future-first-build/#findComment-5769851
