Hey guys,
i've been looking a good looking usb hub to connect my mouse and my keyboard to my pc (i have to unplug them quite often) and is not expensive. Has anybody recommendations?
Thanks in advance!
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/430081-usb-hub-recommendations/
If it has front USB connections just connect them there, but if you need a hub regardless, my favorite ones are these two 1 & 2, I know newegg has quite a few 4 USB connection hubs for cheap prices same for amazon. Or go to a local store like mentioned above.
Regards Elias N Martinez. | Graphic and motion design are my jobs. 3D modeling is my hobby. I do what I enjoy.  Skype: eliasnmartinez1 (please state that you are coming from LTT)
https://linustechtips.com/topic/430081-usb-hub-recommendations/#findComment-5767561
