crash problem
Go to solution Solved by CydiaDash,
it worked
Your welcome. Remember to mark this thread as solved so others will know that it's been solved
my computer crashed and it has the error message that it is collecting info but it is stuck at 55% what do i do
Need more info. Is it a bluescreen? Is it restoring the system, what?
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
https://linustechtips.com/topic/429440-crash-problem/#findComment-5759446
failed overclock so blue screen
Just wait for it to finish.I'm guessing this is a new overclock? Then boot into your BIOS and change the CPU back to stock frequency, make sure it boots up fine and then try and overclock to your normal frequency. Also, remember to quote people to get there attention
My rig:
https://linustechtips.com/topic/429440-crash-problem/#findComment-5759471
well its been at 55% for about 25 minutes now
and it is a new overclock
If this was happening to me I would turn of my PC and boot into the BIOS if the progress bar seriously wasn't moving, that's just me though. If you want to do this I don't accept any responsibility for damage/loss of data, which there shouldn't be, I'm just covering my ass. Also PLEASE quote me so I know when you have replied.
My rig:
https://linustechtips.com/topic/429440-crash-problem/#findComment-5759509
i will quote people now
https://linustechtips.com/topic/429440-crash-problem/#findComment-5759514
Thank you
My rig:
https://linustechtips.com/topic/429440-crash-problem/#findComment-5759519
it worked
https://linustechtips.com/topic/429440-crash-problem/#findComment-5759545
it worked
My rig:
https://linustechtips.com/topic/429440-crash-problem/#findComment-5759553
