Oil Submersion Case
Solved by W-L,
Was Puget the only one that made mineral oil submergion kits? Also what fishtank should I use? Any recommendations?
Puget was the only ones that sold a kit, as for tanks the most convenient is one piece acrylic/plastic tanks since you don't have to ensure seals with glass and aluminum but almost all larger tanks are glass and aluminum.
derekchan ·
Posted in New Builds and Planning1 -
1
3
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion8 -
2
play_circle_filled
Latest From ShortCircuit:
