Foam/micro bubble issue
Go to solution Solved by DieHörnær,
HOLA
So if the foam, not air bubbles, isn't dying down then maybe the speed is too high. http://www.alphacool.com/product_info.php/info/p808_Alphacool-VPP655---single-edition.html
That link is to your pump, I believe it is a manual pump i.e. you have to adjust the speed on the back of the pump there should be a little red screw thingy that you have to rotate to speed-up and slow-down the pump. If not then it is a PWM pump, there should be two connectors coming out of the pump - a 4 pin molex cable and a smaller fan cable, this should be plugged into your motherboard. Install your motherboard software and you can adjust the speed manually via the software, alternatively enter your BIOS [DEL, ESC etc on startup] and change the fan speed settings there.
If the problem persists then it may be due to your coolant or the mixture. Did you do a parts clean beforehand, i.e wash everything out? Is the coolant mixed properly, i.e 1 to X or whatever? If unsure and you have some spare coolant then drain and refill.
If the problem persists I would recommend using distilled water with and additive to see if the problem is replicated.
Hope this helps!
So I build my custom loop only with the CPU, no GPU:
I'm confident the parts are good and the build is done well.
Alphacool Pro 15 LT Res.
Alphacool VPP655
CPU Block
360mm Radiator mounted in the front with in/outlets up against the case roof.
3/8" tubing
Compression fittings, mostly straight but two 90
Mayhem Pastel Koolant
The order is Res - Pump - CPUblock - Radiator - Res
I build everything and when start filling the system I got a lot of foam and the system don't seems to "fill up" so to say, see picture. Not only in the res. but in the whole system, even inside the pump. I've bleed everything with res.top off over night but when shutting the system of the foam starts to build up again, so I guess I've a lot of air in my system. I've also noticed that the coolant enter the res. in quite high speed. Is that common?
I know there are a lot of similar questions, but I've read the tips and nothing seems to help. I've tried rocking the case, pinching the tubing and start/stop. Nothing seems to help.
Can a 90-fitting cause air to enter the pump? Or maybe my drain vault connected to the second outlet of the pump?
Any advice?
post-252150-0-28474500-1439461756_thumb.
https://linustechtips.com/topic/429092-foammicro-bubble-issue/
Have you turned your case around?
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
https://linustechtips.com/topic/429092-foammicro-bubble-issue/#findComment-5755176
How long have you been running it? Sometimes it takes like a day to get all the air out. Keep it running without power to the PC by bypassing the mobo (the thing with a jumper from the green cable to a black cable) Keep turning it to guide the air toward the reservoir and topping it up periodically.
https://linustechtips.com/topic/429092-foammicro-bubble-issue/#findComment-5755216
I read somewhere that it has taken some people up to two weeks for all the bubbles to disappear, it's pretty much different for everybody, I had mine running overnight, about 8-9 hours and all the bubbles were gone.
GPU: RTX 2080 Super        Keyboard: Corsair K70 MK.2 RGB
CPU: i7-9700K        MouseLogitech G PRO Wireless
RAM: 16 GB Corsair Vengance PRO                                                         Headset: Corsair HS70 PRO Wireless
PSU: CX650F        MousepadCorsair MM500 Extended 3XL
MOBO: Asus Prime Z390-A        ControllerDualSense 5
Case: Lian Li Lancool II        CameraCanon EOS M50
Monitor: Samsung Odyssey G5        CoolingCorsair H100i Platinum
The white Rabbit        MicrophoneTrust GXT 252+
https://linustechtips.com/topic/429092-foammicro-bubble-issue/#findComment-5755239
Ok, I guess patience is gold, but I'm a little worried that something is wrong.
So, should I run the system with the top off all the time?
Or run it with the top on, stop the system, turn the case, top off, wait for (how long?), put it back on and the run it again?
https://linustechtips.com/topic/429092-foammicro-bubble-issue/#findComment-5755267
Can in be something then? I mean, what can cause foam to build up?
Can the pump be to small to handel the loop?
Can a bad fitting cause the foam/bubbles?
It would be nice to know some differnet causes to troubleshoot while waiting.
Usually it's just at fill up run the pump at max speed and vary it if your have the Vario version of the D5. If you had a bad fitting or leak your loop would be leaking and everything seems good so just a matter of time. Most take a day or two to bleed out and stop making noises when the air passes through the pump.
https://linustechtips.com/topic/429092-foammicro-bubble-issue/#findComment-5756593
Great! I've done leak testing for about 12-14 hours now and there are no leak from what I can see.. The flow seems pretty good when the system is running, the res is full and just a small small layer of foam on the top. But the second I turn the system off it starts foaming up like, alot. I know it can take time but what's wierd is that there is foam/air inside the pump, which is on the bottom of the case. Shouldn't the water pressure from the res. move the air out from the pump first?
I have the D5-pump which has 5 different speeds but (I think) no way to control it since I can't enter the BIOS to change the voltage.
https://linustechtips.com/topic/429092-foammicro-bubble-issue/#findComment-5763540
HOLA
Hope this helps!
https://linustechtips.com/topic/429092-foammicro-bubble-issue/#findComment-5764354
HOLA
Yes! I found the little red screw thingy. I'll try with a lower speed to see if that helps!
https://linustechtips.com/topic/429092-foammicro-bubble-issue/#findComment-5764634
For all those small micro bubbles in the tubing and blocks they might linger around for a week or so before everything is completely gone as said you might want to lower your pump speed after the initial bleed.
https://linustechtips.com/topic/429092-foammicro-bubble-issue/#findComment-5767219
it will.  when I was bleeding the air out of my system I would pulse my pump from 30% (what I normally run it at) power to full to help dislodge air pockets.
foam isn't going to hurt you loop unless theres' so much that it air locks your pump
https://linustechtips.com/topic/429092-foammicro-bubble-issue/#findComment-5769557
I lowered my pump speed and all the foam went away! The flow into the res. was to high so the micro bubbles in the res. didn't have the time to surface and instead went back into the pump and the rest of the loop.
Thanks for the help! The pump speed is usually not a solution mentioned in forums with the same issues so hopefully this will help someone else googleing around.
https://linustechtips.com/topic/429092-foammicro-bubble-issue/#findComment-5781353
