My brother's asus G750Js laptop is used for his work and its not working anymore. He updated the pc through windows update and then restarted. When it restarted it booted up normally to the desktop. Once the desktop icons load up the screen begins to refresh on an unending loop making the machine unusable. I can open task manager and i see many Thumbnail Handler Extraction(100's) processes running at the same time and windows error reporting running constantly. I looked it up and found this...
http://answers.microsoft.com/en-us/windows/forum/windows8_1-performance/thumbnail-handler-extraction-host-loop-after/9f5fa9bd-85a5-4d3d-a343-f3cb8f0f28a8?auth=1
Please help me, my brother needs the machine working...
https://linustechtips.com/topic/428926-urgent-help-on-work-rig/
Have you tried booting into safe mode and trying from there?
CPU: Intel Xeon E3-1231v3 XX Motherboard: ASRock Fatal1ty H97 Killer XX RAM: G.Skill Ripjaws X Series 16GB (4 x 4GB) DDR3-1600 Memory XX GPU: Asus GeForce GTX 780 3GB DirectCU II XX Case: Phanteks Evolve ATX XX Storage: Kingston SSDNow V300 120GB SSD ; Western Digital Caviar Blue 1TB HDD; Western Digital Caviar Blue 3TB HDD XX PSU: Thermaltake SMART 550W 80+ Bronze
https://linustechtips.com/topic/428926-urgent-help-on-work-rig/#findComment-5753601
Boot into safemode and run a restore
Windows 10 Latest Build
RAID 0 Samsung SSD 970 2tb EVO's (4Tb Store)
RTX 3090
9900k DELIDDED with custom copper Rockitcool @ 5ghz
H150i RGB PRO XT
Corsair Dominator Platinum 64GB (4x16GB) DDR4 3200MHz C16 Desktop Memory 1.35v XMP Profile
Phanteks PH-P1200PS 80+ Platinum - Built-in Power Splitter 1200W Fully Modular
Z390 DESIGNARE (rev. 1.0)
Top Mon #2 ASUS ROG SWIFT PG348Q | NVIDIA G-Sync 100hz
Bottom Mon #1 Alienware Overclocked Refresh Rate #AW3418DW G-Sync 120hz
Server: 2019 DataCenter Edition, 42TB Store RAID 6 | WD Gold Enterprise Class 7200 RPM,SATA 6 Gb/s, 256 MB Cache
https://linustechtips.com/topic/428926-urgent-help-on-work-rig/#findComment-5753724
