I am getting an Antec Earthwatts Platinum 550W PSU and I am wondering if it will power my new system:
Motherboard: Gigabyte GA-Z170-HD3P
CPU: Intel i5-6600K
RAM: 2x8GB DDR4-2400
CPU Cooler: CoolerMaster Hyper 212 EVO
CPU Fans: 2x Scythe Gentle Typhoons 1850dBa (120mm)
PCIe: Wireless AC card
PCI: Sound card
SSD: Mushkin 120GB
HDD1: WD Blue 2.5" 750GB
HDD2: WD Green 3.5" 3TB
GPU: Club 3D Radeon R9 380 4GB
Case Fans: 5x Fractal GP-14 fans (140mm)
USB: 6x devices
I am assuming yes it will as my current/old build has this instead:
CPU: AMD Phenom II 965BE OC to 3.6GHz
CPU Cooler: Antec Kuhler 620
RAM: 4x4GB DDR3-1600
GPU: XFX Radeon 7850 1GB
PSU: OCZ ZS550
which is much more power-hungry than the new one I am building.
https://linustechtips.com/topic/428906-will-550w-be-enough/
PCPartpicker gives a pretty accurate read out of what the max wattage is for your parts, and if you don't like that there's the one from cooler master.
You gotta do you girl. I always say you gotta do you. And if he's doing him, then who's doing you? Because right now, it seems like no one's doing you.
- Stefani Stilton (she / her) 🏳️‍🌈🏳️‍⚧️
https://linustechtips.com/topic/428906-will-550w-be-enough/#findComment-5752843
It should be enough, but I'd go 600W just to be safe
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/428906-will-550w-be-enough/#findComment-5752846
CPU: Intel i5-6600K
PCI: Sound card
SSD: Mushkin 120GB
USB: 6x devices
PSU: OCZ ZS550
550W is good. And that is a good PSU.
https://linustechtips.com/topic/428906-will-550w-be-enough/#findComment-5752848
it's enough but I'd with another brand I had a bad experience with Antec psu's Lol.
CPU: I5 7400 | Motherboard: MSI H110M  | RAM: 16GB G-Skill 2400mhz  | GPU:  NVIDIA  MSI Gaming 4G GTX 970 | Case: Tecware Quad | Cooling: Stock| Storage: Kingston 120gb SSD, 1TB Drive ,  | PSU: Seasonic 620 Watt 80+ Bronze Full Modular | Display: Devant 50 Inch Smart TV   |
https://linustechtips.com/topic/428906-will-550w-be-enough/#findComment-5752907
Even if they arent the most reliable, at least the usually fail in a safe way.
*cough cough* CX PISSER SUPPLIES
https://linustechtips.com/topic/428906-will-550w-be-enough/#findComment-5752917
I wouldn't say safe Since my old Asrock z68 got damaged because of it Lol
https://linustechtips.com/topic/428906-will-550w-be-enough/#findComment-5752961
I havent had any issues, but I guess it happens eventually with nearly every power supply. the CX supplies are just really good at being really bad.
https://linustechtips.com/topic/428906-will-550w-be-enough/#findComment-5752974
