Thermal pad help
Go to solution Solved by W-L,
Would it be bad if I put extra pads there,  because I think I did that with my 1st gpu I did,  was being over zealous getting blocks in place
If they don't have it in the instructions I would leave it, if you were to put thermal pads there it could impact the block from making proper contact to the rest of the GPU and components.
do you not have a booklet of some sort telling you this
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/428802-thermal-pad-help/#findComment-5751626
Sorry I edited my post,  tryed to add a photo and posted by mistake
Those are just coils so they don't really get hot at all but check the instruction manual it will say where to place everything and what thickness of pads also.
https://linustechtips.com/topic/428802-thermal-pad-help/#findComment-5751636
https://linustechtips.com/topic/428802-thermal-pad-help/#findComment-5751706
https://linustechtips.com/topic/428802-thermal-pad-help/#findComment-5751738
Thank you for the response,  I'll just take apart my other block and check to be safe.
https://linustechtips.com/topic/428802-thermal-pad-help/#findComment-5751752
