Please Help! CPU-Memory Compatibility
Go to solution Solved by Guest,
Thanks for the response.  Initially, I thought they were fully compatible as well, but pcpartpicker showed me this:
The Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2400 Memory operating voltage of 1.65V exceeds the Intel Haswell Refresh CPU recommended maximum of 1.5V+5% (1.575V). This memory module may run at a reduced clock rate to meet the 1.5V voltage recommendation, or may require running at a voltage greater than the Intel recommended maximum.
Will this in any way affect my performance?
Not really, You will still be able to have the RAM, you just might have to manually increase the voltage of what the RAM runs at to get it stable running at the 2400MHz
https://linustechtips.com/topic/428748-please-help-cpu-memory-compatibility/
Yes they're compatible, Use PcPart Picker while building a PC
http://pcpartpicker.com/
Automatically checks for comparability flaws
If you give us your budget we can help build one!
not at all
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
Thank you very much)  So far I am incredibly happy with this forum,  people are friendly and responses are lightning fast.  Thanks again)
