Hi my current gpu died and i need to get new one. I will be doing whole system upgrade in about 6-8 months and give current pc to younger brother (he plays lol only) and mother (only facebook and youtube). I might be wrong but amd igpu will be enought for that so gpu will be replaced to new system then.
System i will start using gpu in
Mobo  F2A55M-DS2
Cpu    A4 5300
Ram   Gskill 6Gb 1333 MHz
Psu     Lc power lc420H-12
Old gpu was hd 5570
System i plan to build in 6-8 months
I5 gen 6 not sure will i pick locked or unlocked cpu for now
Mobo msi z170a krait gaming
Ram 8Gb ddr 4 (cheapest i can find)
Psu Nzxt hale82 700W
I would like to avoid unreasonable bottleneck but still not skimp on gpu (i have 400$ at my disposal now and will spend total of 1000-1150$ on pc - this gpu + new system)
I can buy new psu and gpu for total of 400$ if 420W is to low
https://linustechtips.com/topic/428702-gpu-for-low-end-system/
GTX 970, I would say. It would bottleneck current build, but be great for future one.
^This, to be brutally honest. I would personally say hold out for when you actually build, because in 6-8 months, the Pascal GPUs will be around the corner, which would be really excellent for your upcoming Skylake build. If you wanted a decent upgrade for right now, I would find a used 7770 on ebay and go with that for the time being, because that'll play the vast majority of games at 1080p at greater than 30fps when you turn filters off. (I'm building something like this atm, yes it will.) or a 7870 if you wanted a load more performance.
https://linustechtips.com/topic/428702-gpu-for-low-end-system/#findComment-5750551
i recommend getting a R9 380, or if you want to spend a little more a R9 390. both card are pretty much future proof, and definitely fit your 400 dollar budget, with the 380 being 230 bucks on newegg.
the 390 is about 330 bucks
https://linustechtips.com/topic/428702-gpu-for-low-end-system/#findComment-5750553
Honestly... I almost build that pc for myself few years ago.
gladly I didn't
this is why, or when is going for APU is really not the best option specially when upgrading is become necessary, the CPU it self already struggling to keep up with mid-range GPU
I even surprised that the real bench that those APU performance is about Athlon 5000+ combined with HD 4550.
https://linustechtips.com/topic/428702-gpu-for-low-end-system/#findComment-5750578
R9 380 or R9 390, depends on the budget.
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/428702-gpu-for-low-end-system/#findComment-5750595
Just a quick comment about your future build: the NZXT Hale82 is not that good of a power supply (coming from someone who bought the hale90 v2, which is just slightly better)
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
Something like a 970/used 980 for nvidia and a 380/(used) 290(x) for amd.
Ensure a job for life: https://github.com/Droogans/unmaintainable-code
Actual comment I found in legacy code: // WARNING! SQL injection here!
https://linustechtips.com/topic/428702-gpu-for-low-end-system/#findComment-5750600
