Help with my build
Go to solution Solved by Amazingasian,
Is there a way to at least run the games from late this year and early next year?  I really dont have a way to get more cash
PCPartPicker part list: http://pcpartpicker.com/p/mGJpsY
Price breakdown by merchant: http://pcpartpicker.com/p/mGJpsY/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($49.99 @ Micro Center)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($86.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($43.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: MSI GeForce GTX 750 Ti 2GB TWIN FROZR Video Card  ($121.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($54.99 @ Newegg)
Total: $406.83
Generated by PCPartPicker 2015-08-11 23:15 EDT-0400
If you can add an extra $50, get any cheap case you want.
Hi, I'm a 14 year old working on a $400 budget trying to build a pc. I don't know where to even start!  can someone reccomend parts to me to maximize performance and longevity of the system.  I plan on using it for quite a while, and would hope and it could run top games for at least 2 years.  If anyone could help me it would be greatly appreciated ^_^
https://linustechtips.com/topic/428279-help-with-my-build/
You're not gonna be running top games for 2  years on that budget.  I'd recommend at least $600.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/428279-help-with-my-build/#findComment-5744979
Total: $406.83
https://linustechtips.com/topic/428279-help-with-my-build/#findComment-5745047
Total: $406.83
Thank you very much!  I'll take a look at this setup
https://linustechtips.com/topic/428279-help-with-my-build/#findComment-5745074
Total: $406.83
Since you're not over clocking may I suggest getting the i3 4170 and a gigabyte ga h81 at micro center instead. You get a faster CPU but a crappier motherboard with limited ram slots. I3 goes for 99$ and the gigabyte ga h81 goes for 30$ after rebates.
https://linustechtips.com/topic/428279-help-with-my-build/#findComment-5745179
