Blown components.
Go to solution Solved by Enderman,
i brought my parts to a a PC store like memory express and ncix to get tested
I didnt want to risk damaging my new components with ones that I didnt know were ok
the stores tested them and that way I knew exactly what was safe to use
So I am in a thunderstorm and I just lost my desktop due to it. Should I scrap all the parts connected to the computer or should I try and salvage some of them? I have already salvaged my ssd and tested my power supply and it seems to work. Is there a danger or a suggested procedure for verifying the parts safety?
https://linustechtips.com/topic/428039-blown-components/
https://linustechtips.com/topic/428039-blown-components/#findComment-5741666
