Immediate Graphics Card Replacement
Go to solution Solved by Polyvalent,
grab a 290; price / performance they're killer and the XFX version is pretty bomb if you're a fan of them
source: literally just bought one this week
So as of last night my video card died. It was a XFX Radeon HD7970 Ghz edition. Not to brag but this was the best card I've seen. But I know there is better and I'm looking for something on par or better. I've been away from video card news and advancements since I had this reliable one. So what cards AMD or Nvidia would you recommend.
I'm running a i7 4970k as well. Currently mitx and going full atx soon.
Price ceiling is $300 even.
https://linustechtips.com/topic/427995-immediate-graphics-card-replacement/
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
960, 290X,280
CPU: AMD R7 5800X | CPU Cooler: Corsair H115i PRO | Motherboard: MSI B550-A PRO | Memory: G.Skill RIPJAWS V DDR4 3200mhz 64GB | GPU: EVGA RTX 3080Ti FTW3 Ultra | PSU: Seasonic Prime 1300w | OS Drive: Samsung 850 EVO SSD 500GB | Games Drive: Samsung 850 EVO SSD 1TB | Media Drive: 2x WD Blue HDD 1TB in Raid 0 | Media Drive: 2x WD Black HDD 2TB in Raid 1 | Case: Corsair Obsidian 750D | Monitor 1: ASUS PB287Q UHD | Monitor 2: ASUS PG278Q WQHD
just a heads up they get hot
960, 290X,280
Thanks for the quick responce you all. Now those cards onlly cost $250 for the 290, what would you recommend for the next step.
The 290 already looks better than my card by a bit.
http://gpuboss.com/gpus/Radeon-R9-290-vs-Radeon-HD-7970
390x lol, 390/970/980
fuck thoes premade benchmarks
Yeah don't use GPUboss for benchmarks it's bad
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
I'd still recommend a 290 tbh
So I'm looking at the SAPPHIRE Vapor-X Radeon R9 290. What do you guys think about it. I had a Sapphire Vapor-x 5950 back in the day and it ran super cool. Is it worth having the vapor-x or not?
From my research it seemed the Vapor X was best 290, cooler and quieter than most others.
Problems being it's long and it's thick (2.5 slots basically, so might interfere with other PCIe slots).
 CPU:  Intel i7-4790K      Cooler:  Noctua NH-D14     GPU: ZOTAC GTX 1070 TI MINI     Motherboard:  ASUS Z97 Gryphon     RAM:  32GB G Skill Trident X
Storage: 2x 512GB Samsung 850 EVO (RAID 0) / 2TB Seagate Barracuda     PSU: 850W EVGA SuperNova G2     Case: Fractal Design Node 804
currently that wouldn't be a a problem since I have room currently in my mITX case.
Alright just a fair warning haha. No PCIe slots to block when you only have 1 in the first place, eh? I have a PCS+ 290 and it's also 2.5 slots, so basically I can't crossfire this card on my mATX board.
An R9 290, R9 290X, or a GTX 970 would be a good upgrade. AMD cards will give you the best bang for your buck.
CPU: AMD FX-6300 4GHz @ 1.3 volts | CPU Cooler: Cooler Master Hyper 212 EVO | RAM: 8GB DDR3
Motherboard: Gigabyte 970A-DS3P | GPU: EVGA GTX 960 SSC | SSD: 250GB Samsung 850 EVO
HDD: 1TB WD Caviar Green | Case: Fractal Design Core 2500 | OS: Windows 10 Home
is the 290 DX12?
It does support DX12
personally I'd go for a GTX 970 it can handle anything you throw at at high-ultra settings
I bought a 970 SSC for $305 new. Good stuff.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
Also is it worth getting the 290x vs the 290 i posted?
Depends upon price difference. The 290 is pretty close to the 290X in performance so the 290X can't be much more than a 290 for it to be worth it.
I have a 4790k and a 290, I run 1440p.  Only games that have ever given me trouble are Crysis 3 and Witcher 3, so unoptimized trash.  1080p you are laughing most games
thanks. I only run 1080p but I'm glad you chimed in. Really the only games I play are Anno 2070 and Anno 2070.
