heavy cases are usually metal(iron)/steel and light cases are usually aluminum
keep in mind that aluminum cases are also more fragile then the steel ones for example :P
it shouldnt be an issue to sand down a case at all... just sand it and spraypaint it will work fine ( u might need coating though )
https://linustechtips.com/topic/427702-case-mod-help/#findComment-5737295
What would happen if i didn't resurface it after i sand down? would it rust or corrode?
https://linustechtips.com/topic/427702-case-mod-help/#findComment-5737307
the worst that can happen is that it would not stick the paint properly... thats why u want to really coat... for the paint to stick properly and not scratch off super easily
with well painted metal it should never rust or corrode ( or metal just simply beeing in a house instead of the rain :P, it is salts and such that cause metal to corrode and rust .. that usually is from rain n stuff )
https://linustechtips.com/topic/427702-case-mod-help/#findComment-5737311
with well painted metal it should never rust or corrode ( or metal just simply beeing in a house instead of the rain :P )
I mean, if i didn't repaint would there be any issues with the side panel not fitting back to the case or if would start to corrode.
https://linustechtips.com/topic/427702-case-mod-help/#findComment-5737325
there shouldnt be aslong u dont make it wet, metal doesnt corrode/rust from just beeing in a home its usually water / rain that cause metal to corrode/rust... ( psst im a welder aswell as i am a pc tech lol )
https://linustechtips.com/topic/427702-case-mod-help/#findComment-5737331
I have a couple old cases with scratched side panels.
What would happen if i sand the whole thing down to the bare metal below?
One of them has a plain metal interior of the inside of the side-panel, is that just bare metal?
Those panels are usually zinc coated or have a basic paint/primer applied if you want to paint your case I have a write up under General Painting that goes over this.
Note you do not need to sand away all the previous paint on the case to start painting:
http://linustechtips.com/main/topic/407754-modding-faq-common-mods-new-updates/
https://linustechtips.com/topic/427702-case-mod-help/#findComment-5740589
