I bet, if you spend enough time, you could take your components and build them into a custom designed "case", which probably would look super awesome.
EDIT: Found a random example
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
https://linustechtips.com/topic/427689-modding-laptops/#findComment-5737183
With warrant and shit like that I dont think its worth it to mod a laptop because odds are you wont gain any performance or you would have just been better off without it in the first place.
https://linustechtips.com/topic/427689-modding-laptops/#findComment-5737184
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/427689-modding-laptops/#findComment-5737185
