Optical mouse recommendation
Go to solution Solved by TwOne,
Alright after taking a look at these mice and some others I'm considering the following mice:
Steelseries Rival
Corsair raptor m45
Final mouse
Zowie Fk 2
CM Storm Alcor
Anyone know which one would work best with the steelseries QCK mouse mat, I assume it's the SS rival, but I want to make sure.
They should all work fine, since the mat is just cloth, no compatibility issues or something. Many people use the QcK, because of the roughness of the cloth they use, which works fine with atleast 90% of the optical sensors out there. If I had to pick out of that list, I would get the Zowie FK2, but the Zowie FK1 is a bit bigger and costs the same, no other differences, so I'd recommend that over the FK2.
Zowie ZA11 or SS Rival are good for palming with big hands.
Steelseries Rival
Corsair raptor m45
Final mouse
Zowie Fk 2
CM Storm Alcor
Steelseries Rival
Corsair raptor m45
Final mouse
Zowie Fk 2
CM Storm Alcor
Laptop: Intel Core i5-4200H, 8GB RAM, 750GB HDD, GeForce 840M
Desktop: Intel Core i3-6100, 8GB RAM, 750GB HDD, GeForce GTX 750 Ti
