Okay so ive had this problem on and off since upgrading to windows 10. My monitors keep disconnecting and then reconnecting every minute or so. I have 3 monitors 2 * 1080p and a single 4k. Im running a 780ti and because it doesnt have enough outputs on the back to drive all three displays im running one of the displays of my integrated graphics (display port on my motherboard) the other two displays the 4k and the other 1080p are connected through display port and hdmi. This is everything i have tried.
  1. Updating driver software for both the 780ti and the integrated graphics.
  2. When i look at task manager i can predict the monitor disconnect as my cpu usage starts to peak and then spikes ranging from 80-100% load. I have turned of my overclock and my temps are around 35c.
  3. i have tried disconecting each monitor one by one from the display input to see if there is a bad cable, on every monitor the screen still flashes black for about a second.
  4. I have timed each disconnect and they seem to be in the range of 1 minute +/- 5 seconds.
sometimes when i boot my pc maybe ⅖ times it will not have this problem.
When the CPU peaks  an application is run called  ‘Windows problem reporting’ which uses about 70% CPU. During this time my RAM usage is a constant 4GB i have 8GB in total.
So im stuck i have tried everything i can think of can anyone help?
https://linustechtips.com/topic/427377-need-help-monitors-keep-disconnecting/
