building my first pc
Go to solution Solved by Inception9269,
I changed some of the parts around,
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($224.99 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($94.99 @ Newegg)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($110.99 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($44.99 @ Newegg)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($63.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ NCIX US)
Video Card: MSI Radeon R9 390 8GB Video Card  ($324.98 @ SuperBiiz)
Case: Cooler Master Storm Enforcer ATX Mid Tower Case  ($75.99 @ NCIX US)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($64.99 @ NCIX US)
Mouse: Razer DeathAdder Chroma Wired Optical Mouse  ($54.99 @ Amazon)
Other: RAZER BLACKWIDOW CHROMA STEALTH ($170.00)
Total: $1280.89
Generated by PCPartPicker 2015-08-09 20:15 EDT-0400
buy 8.1 pro from g2a from $25 then do a free clean install of 10 pro
I've been planning my first pc build for about 6 months now and i feel like this is the hardest thing ive ever done. I need some help! make whatever changes you deem necessary, it will be GREATLY appreciated.
This pc will be used exclusively for gaming. I would like to be able to run today's high demanding games in ultra or near ultra settings if possible given my
1.3k budget.
this is what i have so far:
http://pcpartpicker.com/p/YYdbgs
https://linustechtips.com/topic/426955-building-my-first-pc/
You have too much RAM. 8GB is more than enough.
Also, your PSU is lacking a bit of headroom. I would go with at least 500W.
For the rest, solid build.
Also, i'd recommend a SSD a lot, it's the biggest upgrade you can get IMO
Oh and another thing, a mechanical keyboard isn't that big of a deal. I would drop that and get a regular keyboard + SSD in stead.
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5727621
Get a bigger power supply and try for an ssd. I ran my old pc off a mechanical drive and when I got my ssd it was amazing!
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5727630
8GB RAM is enough I would at least get 500W PSU and don't get a CX PSU they're not good quality also add a SSD
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5727632
Total: $1280.89
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5727679
if you drop the 200+ spent on mouse and keyboard you could fit a 980ti for a little more in comparison.
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card  ($673.99 @ SuperBiiz)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($24.99 @ NCIX US)
Total: $1429.90
Generated by PCPartPicker 2015-08-09 20:17 EDT-0400
all mice and keyboard are pretty much the same, "gaming" brands just being a waste of money
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5727704
1.3k budget.
Total: $1280.89
this
or as @Inception9269 said, get somecheaper mouse and keyboard and get a 980ti or a 980
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5727723
Incidentally, if you insist on 16 gigs of RAM, a 16GB kit is generally cheaper than getting two 8's. Barring that, I'd probably trim a bit on some of your higher-dollar parts (do you really need a $100 case? Not saying it's not good, but that's a lot for a box..) to get your hands on an SSD. If you trim, say, $30 budget on each for your video card and your CPU, $10 on your case and get an extra $10 back from your RAM (assuming sticking with 16GB), you've got about $80 for an SSD, which can start getting you into 240GB drives; if you can't do that, 120s can be got for under $50. And trust me, you'll notice the difference with an SSD, in some cases more than from your video card.
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5727742
I suggest 16 gb if he's using it for ANYTHING besides gaming, and I think 16 gigs is entitled to be there on a 1.3k machine.
Python/C# Programming
Code to learn, don't learn to code. -Napalm
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5727743
Here you go PCPartPicker part list: http://pcpartpicker.com/p/BvspsY
Price breakdown by merchant: http://pcpartpicker.com/p/BvspsY/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($251.98 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($25.98 @ OutletPC)
Motherboard: Asus Z170-P D3 ATX LGA1151 Motherboard ($124.99 @ Newegg)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory ($89.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($66.99 @ SuperBiiz)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card ($309.99 @ NCIX US)
Case: NZXT H440 (White/Black) ATX Mid Tower Case ($99.99 @ Newegg)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($86.98 @ OutletPC)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard ($119.95 @ Amazon)
Total: $1360.81
Generated by PCPartPicker 2015-08-09 20:34 EDT-0400
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5727806
I know i should, i just cant get over the LEDs.
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5727960
added a bigger psu for sli 980 in the future:
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($64.99 @ Amazon)
Motherboard: MSI Z170A KRAIT GAMING ATX LGA1151 Motherboard  ($149.99 @ Newegg)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR4-2400 Memory  ($57.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($43.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card  ($514.99 @ SuperBiiz)
Case: Fractal Design Define R4 Blackout with Window ATX Mid Tower Case  ($74.99 @ NCIX US)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($68.99 @ SuperBiiz)
Total: $1291.90
Generated by PCPartPicker 2015-08-09 21:05 EDT-0400
BigDay
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5727968
Total: $1291.90
If he's only gaming, what's the point in a 6600 over a 4690?
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5728021
Total: $1280.89
ok, we had another person agree with this, so im going to roll with this set up for a few days and see what others think.
https://linustechtips.com/topic/426955-building-my-first-pc/#findComment-5728046
