Is it ok to mix metals in custom loops
Like say I use the EK Supremacy EVO Nickel+EK-FC980Ti Nickel cpu and gpu blocks.They are both made of nickel.However I want to use the Alphacool Full Copper Monsta series of radiators.Is it ok to use those 2 in the same rig?
Insert   Dank   Signature   Here.
https://linustechtips.com/topic/426947-water-is-cewl/
To my knowledge, as long as you aren't mixing aluminum as well, corrosion shouldn't be a huge problem. Nickel and Brass are pretty close on the Galvanic scale, so it should be fine (Silver/Nickel/Brass/Gold/Copper can be fairly safely mixed.)
I like good humans and good food
https://linustechtips.com/topic/426947-water-is-cewl/#findComment-5727543
be sure to use an anti corrosive
Its a Championship not a Belt!
https://linustechtips.com/topic/426947-water-is-cewl/#findComment-5727544
That's not a problem since they aren't dis-similar metals but note if your using nickel waterblocks do not use distilled water and silver coils they have issues with being barely dis-similar metals and making the nickel plating flake off. It's better to use distilled and a biocide of sorts like PTnuke.
https://linustechtips.com/topic/426947-water-is-cewl/#findComment-5732892
