Mouse problems
Go to solution Solved by ZetZet,
and one of thes will solve the problem definetly?
no, but if it works perfectly on a table it should work perfectly on a hard mouse pad. going from cloth to cloth, like you wanted to do changes absolutely nothing.
So basically my Steelseries sensei raw started having tracking issues on my cloth mouse pad. And I've read that the issues are most likely caused by the laser sensor. So I was thinking of buying a hard pad ( ASUS STRIX GLIDE SPEED ) , and my question is if that should do it, or am I in for a new mouse all together?
https://linustechtips.com/topic/426576-mouse-problems/
And where can I modify that?
at configuration > mouse > pointer options u see a little box > Enhance pointer precision... with this enabled ... mouse acceleration will be enabled   disable this if it is enabled
if u still get weird accelerations,  click and hold the slider bar for mouse sensitivity, drag it all the way to left then to right and left a few times and put it back to the middle ( somtimes its stubborn and needs a lil mashing like that to disable )
https://linustechtips.com/topic/426576-mouse-problems/#findComment-5723285
laser mice have acceleration built in anyway  :P
https://linustechtips.com/topic/426576-mouse-problems/#findComment-5723292
I've disabled that a long time ago, the tracking is really laggy, sometimes the pointer just doesn't move for a second or so, and if a draw a straight line from left to right it goes downwards.
https://linustechtips.com/topic/426576-mouse-problems/#findComment-5723314
Guess I'm funked?
The mouse works normally on my desk tho :/
oooo prolly just a fked mousepad then due to dirt ( cloth does absorb dirt ) try going over the cloth with a knife see if it turns white, if it does its dirty as heck and that can cause issues ( really really rare but it can cause it ;x )
my suggestion get some cheap ass mousepad ( cloth one ) from a cheap ass store or w/e .. cheapest of cheapest u can find... actually get a few of them , if one wears out pop in the other one :D haha
ive had expensive mousepads and cloth is always the best really... plastic is good in the begin but it will also wear out AND wear out the bottom of ur mouse quicker than cloth
also do not get color printed mousepads coz different colors can cause issues on some laser mousies
https://linustechtips.com/topic/426576-mouse-problems/#findComment-5723323
Guess I'm funked?
if it does then hard mouse pad is what you need. Laser mice have problems with cloth pads most of the time.
https://linustechtips.com/topic/426576-mouse-problems/#findComment-5723329
that's cloth
https://linustechtips.com/topic/426576-mouse-problems/#findComment-5723349
https://linustechtips.com/topic/426576-mouse-problems/#findComment-5723375
https://linustechtips.com/topic/426576-mouse-problems/#findComment-5723390
Could you suggest one?
I use a mionix propus 380 and its nice and slidy, with a good rubber base to stop it from moving on the desk
RIG:FX-6300@4.5GHz 1.4V with Hyper 212 evo with LTT NF-F12:MSI Overclockers R7 260X:4x4B Crucial Ballistix Sport:GA-970A-UD3P:1TB Seagate Brracuda & 120GB Crucial M500(OS and Programs)&Sandisk SSD PLUS(Games) In a Bitfenix Comrade with an NF-F12 as exhaust and OEM case fan as front intake
''time you enjoy wasting is not wasted time''
https://linustechtips.com/topic/426576-mouse-problems/#findComment-5731193
