difference between midi interfaces.
just wondering what the difference is between lets say a $50 maudio uno, and a $80 m-audio midisport. will they do the same thing +/- a few features? all I want to do is take my piano/keyboard, and use it as a midi device for some projects.
Is it bad that my dream setup only costs a few thousand not counting the obutto?
CPU: FX-8320
Motherboard: asrock 970Pro3 r2.0
Memory: Team Zeus Blue 8GB DDR3-1600 Memory
Video Card: Sapphire Radeon R9 280 3GB DUAL-X Video Card
Case: Deepcool TESSERACT BF ATX Mid Tower Case
Power Supply: EVGA 500W 80+ Certified ATX Power Supply
SSD: MX100 128GB
HDD: WD 2TB black edition
https://linustechtips.com/topic/426381-difference-between-midi-interfaces/
i dont know the difference between maudio uno and maudio midisport but i do know that all ION Midi keyboards are of good quality and would do the job for u ( had them myself infact i got one right now , and i know for a fact that their good quality )
about the interfaces , i think it doesnt matter too much for personal use
Depending on the keyboard, you might be able to skip the MIDI interface and plug it in with USB as get MIDI control that way
Feel free to message me if you want to chat!
It doesn't have a USBport, so I am guessing you can't do that... I wonder if I could wire something like a raspi into a piano.... make it a "smart" keyboard.
CPU: FX-8320
SSD: MX100 128GB
Sounds tedious, although MIDI is a pretty simple concept. I think either of those interfaces with do fine. You can't really do MIDI badly I don;t think
