Ok so ive installed osx yosimite on my computer using unibeast and im now at the mac desktop but how do I setup the computer to boot?
Please help me im really new to hackintoshing so.... yea
I dont mean to push you away from this forum but if our resonate hackintosh owners cant reply soon enough check out tonymacx86 their all hackintosh
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/426259-hackintosh-help/#findComment-5719566
I guess you have installed OSX on a physically different Disk than Windows. All you have to do in this case is adjust the boot order in your bios.
And don't forget to quote somebody if you answer him.
I once had one of these, now I've got this.
https://linustechtips.com/topic/426259-hackintosh-help/#findComment-5719632
You will want to use the unibeast tool from Tonymac. It contains the tools needed to allow your system to boot without the install disk. You have a choice between either Chameleon or Chimera, they both do the same thing but I think Chimera has more options. There is also a selection of kexts (drivers) and fixes in the unibeast tool.
https://linustechtips.com/topic/426259-hackintosh-help/#findComment-5721392
