So yesterday i asked a question about my selected psu and one guy said that they are known to start fires and some other scary shit, is that true? Can Corsair VS 550W ATX catch on fire?
i5-4690k, R9 380 4gb, 8gb-1600MHz ram, corsair vs 550w, astrock h97m anniversary.
https://linustechtips.com/topic/425901-psu-caught-on-fire/
any psu from corsair and other top notch manufacturers wont really start fires and arent known for it, only an idiot who would try and draw more out of a psu then its capable doing ( like knowing ur psu is 400watt and draw 500-600 out of it ) then u can get issues yeh
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715434
Can power supplies start fires? Of course, in fact I was looking for parts tonight and found one of my PSU's that had "burned". Will the Corsair VS 'whatever' catch on fire? I doubt it, Corsair doesn't make crap(at least at the time of typing this). Unless you are drawing too much power from it(like having a PSU too small for the build), you shouldn't experience any problems.
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715441
As long as you are not pulling more than it can handle or keeping at constant 530-600W load it will be fine.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715450
That guy also mentioned about how cheap the components of corsair are :D
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715455
I feel I should mentioned I pointed I out that It could start a fire IF you overclock a CPU and GPU on it that already draw around 400-450W.
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715457
Yes they can... If the conditions are  right... any PSU can cause fires...
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715471
But usually better quality units have an overload of 100W or more
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715480
Can they start fires? Yes
Will your house burn down? No. The fire is more of a tiny explosion and unless your PSU or Case is made of flammable material, there no real life danger.
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715483
Lets say it does brake and gets all smoky, will it damage other pc parts?
Yeah, there's a chance it could do that.
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715486
Lesson? Don't buy Corsair VS and CX - CS and above only.
And don't OC on a crappy PSU :P
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715489
Stop scaring me :D
Either don't OC and get a lot of headroom or get a good quality unit from a better place - SeaSonic, XFX or EVGA.
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715516
http://pcpartpicker.com/p/wJk6zy
The list of parts, if necesary
No hard drive? You should be fine though.
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715575
The list of parts, if necessary
Don't overclock on a "H" board with a VS PSU ._. You are GUARANTEED to fry the motherboard and likely will be getting close with the PSU.
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715598
but if i'll get a better PSU there should be no prob with overclocking?
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715605
"Z" boards are for overclocking because they have a beefier power delivery. If you try to OC on a "H" board you will surely fry the VRMs and it will not work anymore.
https://linustechtips.com/topic/425901-psu-caught-on-fire/#findComment-5715611
