Logan over at the TekSyndicate did a video review on the Xigmatek Dark Knight Night Hawk CPU cooler.
Video:
Newegg: http://www.newegg.com/Product/Produc...82E16835233029
To be honest, I think you'd be better off getting a Cooler Master 212+/EVO and getting some IC Diamond thermal compound and some Noctua fans if you want something silent and good temperatures, but I don't know how much it compares to the Xigmatek.
https://linustechtips.com/topic/4259-50-cpu-cooler/#findComment-51456
Video:
I also think that you should do it the way above if you want a silent cpu cooler.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/4259-50-cpu-cooler/#findComment-51472
Video:
I own that cooler. It has trouble with more than 1.3V on sandy bridge, running a single NF-F12.
https://linustechtips.com/topic/4259-50-cpu-cooler/#findComment-51480
If you aren't going to be pushing your cpu very hard, then the cooler master hyper 212 or hyper 212 evo should be fine. They are like $30 and $35. If you need something with a little more cooling potential, then:
http://www.newegg.com/Product/Produc...82E16835103055
http://www.newegg.com/Product/Produc...82E16835118091
http://www.newegg.com/Product/Produc...82E16835426023
http://www.newegg.com/Product/Produc...82E16835233029 (<-- never seen that one before but it looks friggen awesome. xigmatek makes decent coolers)
I would personally use the zalman one because i know they make very high quality heatsinks, but i understand that you may be on a budget. Also you can't go wrong with noctua fans. Their heatsinks and fans are pretty much God-tier in air cooling (even if their color choice is sub-par) also they can be expensive...
Also don't use the included thermal compound. More often than not, its not so great. Use something like IC diamond, Arctic Silver, Arctic Cooling mx4) thermal paste is cheap and one tube will last a very long time.
Corsair Obsidian 800D | Msi GD-80 z68 | Intel Core i72600k (stock speeds at the moment) | Msi Gtx 570 twin frozr III | 8GB Corsair Dominator @1600mHz | Coolermaster evo 212 temporary) | Cooled by Gelid Wings | Intel SRT smart caching | Windows 7 ultimate x64
https://linustechtips.com/topic/4259-50-cpu-cooler/#findComment-51550
Video:
What noctua fans are good?
https://linustechtips.com/topic/4259-50-cpu-cooler/#findComment-51737
HOLY CRAP! i have never seen this before, i havent heard any reveiws, but i dont care i will buy four of them! i want my house to be made of these
CPU: i5 3570K @4.5GHz    GPU: R9 290   MOBO: ASUS p8z77-v  RAM: 8Gb corsair vengence   CASE: ARC MIDI  PSU: XFX pro 550W  HDD: 2tb segate baracuda
https://linustechtips.com/topic/4259-50-cpu-cooler/#findComment-52616
