5820k vs 4790k at same clock speed.
What do you mean by dont forget to follow your topics???
And thanks but if thats the case then why do people that benchmark these in crysis, witcher, ect get different frame rates if they are all the same with gaming after an i5?
If you follow your topics (by using that button in the top right) you will get notifications on replies to your topics even if people don't quote you in their post (like I did)
I said significant difference. Frame rates will vary slightly depending on which processor you have over an i5, but not so much as to if you're only going to be gaming you should go out and buy a 5960X because it will only give you about an 8ish FPS difference. (unless of course you want to 4-way SLI Titans, in that case you will need X99 for the PCI-E lanes.) That is also another reason some people with higher-tier processors can also get higher FPS rates. If someone did 4-way SLI Titans with an i5, it would bottleneck because it doesn't provide enough PCI-E lanes to even handle those 4 cards. Someone with an X99 processor on the other hand will have the PCI-E lanes for those 4 GPUs and therefore get better gaming performance.
