Sorry to bother you folks but I'm fairly new to the PC world. I recently received a PC from a friend of mine, the sounds works when I use an HDMI cable instead of VGA, but when I switch to VGA, I can't hear a sound from my monitor, speakers or headphones. I updated all the drives and even reinstalled realtek audio. Can You guys please help me out?
https://linustechtips.com/topic/425600-no-sound/
where are you plugging in the speakers/headphones? HDMI carries audio in it while VGA Does not. Plug your speakers/headphones into the pc itself if you are not. Also use HDMI dont use VGA
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/425600-no-sound/#findComment-5711685
Unlike HDMI Vga doesn't carry audio signal so you have to use the audio output of your pc.If you use hdmi you can use the audio output of whatever it is connected to
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/425600-no-sound/#findComment-5711726
VGA is really old tech from the 1980s. I'd listen to this guy and use HDMI instead ^
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
https://linustechtips.com/topic/425600-no-sound/#findComment-5711942
The reason why I'm using a VGA monitor atm is that I still haven't bought a monitor that supports HDMI, I'm a broke college student so It has to wait and I plugged my speakers and headphones to their respective ports. I would post a pic of that realtek audio manger that keeps popping up, but I don't know how to  :unsure: .
https://linustechtips.com/topic/425600-no-sound/#findComment-5711990
